v80z Posted March 3, 2006 Share Posted March 3, 2006 Well the car is to a point. It moves fairly reliably. It will turn the tires over on that solid axle no problem. It has a stumble when it transitions between 2bbl and 4 bbl I think. I am looking for someone to show me how and what to do to make this motor run better. I am sure alot has to do with all the various parts I have cobbled together and alot of unknowns and inexperience on my part. The only thing I have done is advance the distributor a few degrees against its rotation to try and fire it earlier to get the top end. 1970 sbc 350 .030 10.25:1 CR Stock Bottom stock heads screw ins 1.94 intakes 1.6 exhaust Crane race roller rockers 1.5s springs to support .550 lift edlebrock airgap edlebrock 750 vac 2ndary .508 lift solid .012 hot gap(will get cam card out and post full cam specs) hei with crane cd ignition grafted in. Anyway if there is anyone close to Yorktown Va that might have some time or have an orderly plan for going about this the smart way I would be most appreciative. Thanks Quote Link to comment Share on other sites More sharing options...
boodlefoof Posted March 3, 2006 Share Posted March 3, 2006 If you need shop help, Tidewater Z is right up the road from you. Guys over there know their stuff, and the shop is run by the head of the Tidewater Z Car Club and the Z Car Association of Richmond. Quote Link to comment Share on other sites More sharing options...
