DarrellBuddy321 Posted March 3, 2006 Share Posted March 3, 2006 The 8 pin connector by the ecu. The YW wire that you are suppose to use, on my harness the wire is solid white. Is it still the same wire? The 6 pin connector by the battery. the LR wire that goes to the fuel pump relay, does anyone know where to attack it on a 79 zx? Quote Link to comment Share on other sites More sharing options...
DarrellBuddy321 Posted March 4, 2006 Author Share Posted March 4, 2006 i solved most of my problems except for On the ignition switch the BW is that the signal for the switched ignition? Is there where i connect the Y from the 8 pin connector? One more thing to ask. WHERE IS THE CONNECTER FOR THE FUEL PUMP RELAY...? (might be a stupid question, BUT I DONT KNOW!) Quote Link to comment Share on other sites More sharing options...
HeatRaveR Posted March 16, 2006 Share Posted March 16, 2006 One more thing to ask. WHERE IS THE CONNECTER FOR THE FUEL PUMP RELAY...? (might be a stupid question' date=' BUT I DONT KNOW!)[/quote'] Do you mean where does the fuel pump relay connect to the engine management? Or is this for kill switch purposes? If so, I just went straight to the fuel pump relay (behind the glove box) to access its wires. Quote Link to comment Share on other sites More sharing options...
