Venture Posted March 6, 2006 Share Posted March 6, 2006 I just painted my car and now I need to put it all back together. I bought the precision weatherstrip kit while I was at it, but I cant figure out how to replace the seals in the quarter windows. I must be missing something, because I cant figure out how to take the frame apart, and I really dont want to break anything. The old seals are crusty, so I really don't want to put those back in. Anyone got any tips or tricks. Thanks a bunch. P.S. I'll post pictures as soon as I get it back together. Quote Link to comment Share on other sites More sharing options...
jbc3 Posted March 6, 2006 Share Posted March 6, 2006 As I recall, Take the outer seal off and there are a couple of screws holding the frame together. Once the screws are out I had to work to get the frame apart. Jody Quote Link to comment Share on other sites More sharing options...
AK-Z Posted March 6, 2006 Share Posted March 6, 2006 You have to remove the seal that surrounds the frame then there are 4x screws on the upper and lower parts towards the section that meets the door. the section that meets the door has a strip of metal and rubber, I don't recall having to have to remove that part. the part that its attached to is what needs to be removed. Once the screws are out that piece should pull out but you have to use force. Quote Link to comment Share on other sites More sharing options...
Venture Posted March 7, 2006 Author Share Posted March 7, 2006 Thanks, I'll have to try that tonight. Quote Link to comment Share on other sites More sharing options...
Z-8 Posted March 7, 2006 Share Posted March 7, 2006 I figured it out by going to a junkyard and just taking it apart. You will have to remove the inner trim around the window, and also the silver outter piece(if you have a ZX). Quote Link to comment Share on other sites More sharing options...
