Guest z31maniak Posted March 14, 2006 Share Posted March 14, 2006 i have an 86 2+2 it was a slavage car it started overheating and my mechanic said the timing belt needed change so i got that done didnt help added a thermostat since it didnt have one and didnt help finaly a rad wich fixed the problem after siting 3 years drove it for one day put some fresh gas in it parked it started it the next day and the motor was realy hesitant wen i step on the gas its clearly missing or a cylander is dead cant tell why i had a tune up wen i bought the car and only drove it for 6 months and i noticed it has a very exhausty smell and the motor will still heat up wen it stands still but as soon as i touch the accelerator it drops any guess what might be casuing my problem? Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted March 18, 2006 Share Posted March 18, 2006 Incomplete sentences, try again. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted March 18, 2006 Share Posted March 18, 2006 You clearly need to use , and . in your sentences. My guess is that your injectors or the fuel filter are getting clogged. I would of done a compression check rather than a tune up. I would also clean the electrical connections on the injectors with a wire brush. There could be ALOT of things wrong, and hard to pin point. Quote Link to comment Share on other sites More sharing options...
