Guest Anonymous Posted July 3, 2000 Share Posted July 3, 2000 Hello, have been reading this site now for a couple of weeks. Just decided to join in. Kinda feel like I know alot of you guys. My mechanic is installing my 93 Camaro v8 next week. I have a great t350.My car is a 78 280z. Would like to use it...but I am afraid of my rear end ratio being a 3.9 instead of a 3.54 or lower. How do I tell? I know the t350 will make the motor scream at 65 with a 3.9 ratio. Maybe I wont have to buy a 700overdrive if I have the 3.54 or lower. Thanks in advance. p.s. I do have a 79 280zx 2+2 parts car with a good rear end. Wonder what its ratio is? Thanks in advice. I tell ya, there is a site for everyone huh? Quote Link to comment Share on other sites More sharing options...
John Scott Posted July 4, 2000 Share Posted July 4, 2000 Spin one axle (make sure the other remains still) 2 revolutions. Count the # of turns the pinion flange makes. 3 1/2 will be a 3.54. almost 4 will be a 3.90. JS Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted July 4, 2000 Share Posted July 4, 2000 I'm not a Z expert but I THINK I've heard that the 2+2 cars actually had a LOWER ratio rear in them! This is due to it's heavier weight so before you consider swapping it in you'll want to check this out. ZCAR.COM would be a good place to search if no one else here knows for sure. In the end I think you'll be happiest with an overdrive tranny - even a 3.54 will be making some noise at a 65mph cruise. Get it running with the trans you've got and then decide I suppose, I think the physical sizes of a T350 and a 700R4 are such that you might be able to use the same driveshaft with both but I'd double check to be sure if the cost of a driveshaft matters much to you. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted July 4, 2000 Share Posted July 4, 2000 Here is a URL all Z owners should bookmark. Scottie http://zhome.com/ZCMnL/tech/GearRatios.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 6, 2000 Share Posted July 6, 2000 Just for info, the t700 is longer than the t350 so the same driveshaft would not work. Quote Link to comment Share on other sites More sharing options...
