Guest big_bitty Posted March 15, 2006 Share Posted March 15, 2006 i dont plan on doing a whole lot to my motor, basically just a cam (crane cams computer cam for an 88 ho 5.0), will the sd computer i pulled out of my mustang be good enough????????? Quote Link to comment Share on other sites More sharing options...
Guest big_bitty Posted April 13, 2006 Share Posted April 13, 2006 does anyone have an answer for me????? i really need to know this Quote Link to comment Share on other sites More sharing options...
BringIt Posted April 13, 2006 Share Posted April 13, 2006 put a maf on it Quote Link to comment Share on other sites More sharing options...
Rival5 Posted April 13, 2006 Share Posted April 13, 2006 Dont know how i missed this but id go MAF more flexability for the future Quote Link to comment Share on other sites More sharing options...
strotter Posted April 13, 2006 Share Posted April 13, 2006 Well, I'm a GM kind of guy, but I can chime in just a teeny bit on this one. As a general rule in the smallblock world, there seems to be a slight preference for speed-density systems for performance applications. From what I've gleaned (mostly at thirdgen.org), the sd systems are considered more versatile than speed-density, though it's almost universally necessary to fiddle with the bpm maps and lot of other goodies in the ecu eproms. That said, the maf systems seem more able to adapt without modification to relatively minor changes in the motor; however, as soon as major changes are made you also have to get into their ".bins". The sd guys, arguing from this point, claim that, since you're fiddling with the brains anyway, you may as well use a system that won't limit intake volume (which the maf does, 'cause you're limited to the "factory" sizes available). Personally, I've always thought that maf is a more "elegant" system, but that's just me. Many modern systems, certainly on the GM side of things, essentially use both simultaneously. The guy to ask is GrumpyVette, who posts here on HybridZ occasionally. He's one of the real old-skool pioneers and has forgotten more about efi systems than most of us will ever know. Quote Link to comment Share on other sites More sharing options...
Lason Posted April 19, 2006 Share Posted April 19, 2006 Do a MAF conversion. The SD setup will probably run poorly with the SD system in place after you put a cam in it. Quote Link to comment Share on other sites More sharing options...
