Reverse coolant flow for turbo engine
umm..
its not the coolant that is causing detonation
yes the effectivness of the coolant reduces the chances of detonation.. but the key to preventing detonation is proper air/fuel ratio and timing..
you can have pre-ignition of there is a hot spot ... or detonate with a poor mixture or high cylinder temps..
an F54 block has better webbing for improved cooling.. buy an aluminum or 4 core radiator.. and a good electric fan and you wont have to worry about anything
the Nissan engineer's have it the way it is for a reason..
ok, I'll get you guys headed back in the right direction, here is a short paragraph from grape apes site.
Reverse Flow Systems
As I said earlier, it makes sense to put the
coolest coolant to the hottest parts first to bring the
temperatures down as much as possible, the
already heated coolant can help bring the
temperatures of the coolest parts higher and make
everything more even. To do this the coolant must
flow in reverse (compared to most systems). The
problem with reverse flow systems is that the pump
tends to cavitate easier (even with a good
aftermarket pump). To limit cavitation, a higher
boiling point of the coolant helps and so does a
higher system pressure.
