Do I have an IAC?
badjuju
The zxt does not have an IAC(idle air controller) as far as they are talking. To them (DIY auto) an IAC is either a stepper controlled or PWM idle air controller. The zxt has the AAR (auxilary air regulator). That is the bosch part with 2 pin connector and coolant running through the base. It only needs a 12volt signal while the car is running and then the bimetal valve slowly closes as the coolant heats up. It gives you a real basic fast idle function. My car worked great with it, but I did not have AC and other things that drag the idle down.
