Guest ExpertHandler Posted March 22, 2006 Share Posted March 22, 2006 I have a 71 240z with a stock motor for all that I know Has header and exhaust bah and has a electric piston driven fuel pump "loud as hell" so anoying anyways I just got a fuel pressure regulator to keep it from blasting my carbs to hell with gas where is the best place to mount the pressure regulator and around what psi should i be running ?? Quote Link to comment Share on other sites More sharing options...
AK-Z Posted March 22, 2006 Share Posted March 22, 2006 Not to sure but I think I've read on heres somewhere that it was 6 psi because its carbed. Quote Link to comment Share on other sites More sharing options...
2126 Posted March 22, 2006 Share Posted March 22, 2006 IIRC, the recommended fuel pressure for the SUs is 4 to 4.5 psi. With new needles and seats in the carbs you can get away with a bit more. Anything over what you've mentioned is asking for trouble. Quote Link to comment Share on other sites More sharing options...
Pyro Posted March 22, 2006 Share Posted March 22, 2006 Mount the regulator on the cool side of the engine compartment (passenger side). A good place would be on the firewall between the battery and the hood release so the fuel line will not be heated up by the hot air from the radiator. 4 psi is right for SU's. Get a Mallory comp70 if you want a quiet pump. I bet you have a Holley pump (loud as hell). No need for the mechanical pump. Quote Link to comment Share on other sites More sharing options...
Guest ExpertHandler Posted March 23, 2006 Share Posted March 23, 2006 the pump is a little square thing Quote Link to comment Share on other sites More sharing options...
Guest ExpertHandler Posted March 23, 2006 Share Posted March 23, 2006 how do i need to run the return with the regulator ?? I got the stupid spector regulator from the motorsport catalog i think im going to dump it and go with an aromotive that has a mount for a guage and a return line Quote Link to comment Share on other sites More sharing options...
