mrparks Posted March 23, 2006 Share Posted March 23, 2006 Replaced the wiring harness, which was amazingly easy. The only problem is that the original fuel injection harness in my Z ('77 280z, manual tranmission) had a connector that is shaped like a backwards L, with two wires leading from it. It was hooked in the general area of the ignition area. I can't recall the year of the car that donated the "new" harness. It was also a 280z. The main problem is that the donated harness has a spade connector with a single wire. That is bothering me, for obvious reasons. (Obvious reason being that it it's one of the loose ends that are left) The other "Loose ends" are two female bullet connectors. I have a Nissan 720 pickup ('84, Manual transmission) that I pulled the starter off. It bolted up with no problems. Assuming that this starter is functional, will it work with the L6? Oh, and will the seats out of a '89 240sx fit into the Z? My originals are a little rough. In fact, when I bought the car the previous owner had duct-taped a floor mat over the foam. For $490, I still think it was a good deal. Quote Link to comment Share on other sites More sharing options...
