Driveshaft removal???
The new guy here. How do you go about removing the original drive shaft from the rear of the car? (I'm getting ready to pull the engine next week) No way a typical wrench can fit in that tight of a space or am I missing something? Also on my car there is a (Splash guard???) on the passenger rear (A arm? below the drive axle) but there is not one on the drivers side whats up with this? Any help would be greatly apperciated.
Thanks,
I read this old post from Jeff Davis from IZCC and this is exactly how I did it no sweat.
...removing those four 12mm nuts from the rear drive shat is probably the
single most time consuming portion of a trany swap, it's really not that big
of a deal. This may not be the best way to do it, but I've found the
easiest way for me is to have the rear on stands with the wheels free to
spin and the trany in neutral. I usually have the front end up on ramps for
trany clearance when I'm doing this. Anyway , I stick the opposite end of
my cheap 12mm box wrench (the enclosed circle end) on the nut, then spin
the drive shaft with my hands to knock the nut loose as the wrench wacks
against the floor of the unibody. I tighten them the same way. BTW, I'm
talking a '77 280 here.
-jeff
