R200 flange fitting vs. slip (spline) fit
Greetings,
I currently have an R200 with the flange fittings for the half shafts. After completing the fabrication of my CV axel adapters (Scottie, this is why I haven't been buggin you about solid U-joints... nothing personal) I need to find a slip fit R200. Is it possible for me to remove the flanges and have a spline opening, or am I just dreaming. I'd REALLY like to not swap another differential (on my third R200) but I might not have a choice. Any advice is appreciated.
-Andy
Are you referring to the flange that comes out of R200 that the halfshaft bolts up to (4 bolts)? If so, that should pop out. I just removed mine last night and I unbolted the halfshafts at the companion flange and use a small pry bar to pop the splines out of the diff. Sure is easier than 8 bolts to remove a halfshaft.
Scottie
Scottie
71 240GN-Z
http://www.mindspring.com/~vscott911/gnz.html
