510six Posted April 1, 2006 Share Posted April 1, 2006 http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=63ef&.dnm=179c.jpg&.src=ph http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=63ef&.dnm=93f7.jpg&.src=ph Even though I am not running MS I still chose to use the 36-1 wheel and the EDIS coilpack for use with the AEM EMS.The Ford parts thanks to you MS people are common and work very well. Quote Link to comment Share on other sites More sharing options...
clayborne Posted April 2, 2006 Share Posted April 2, 2006 wow that is looking great i thought about going this route but am still too intimidated by it Quote Link to comment Share on other sites More sharing options...
pete280z Posted April 2, 2006 Share Posted April 2, 2006 Very cool. Do you have any photos of how you attached the 36-1 wheel? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 2, 2006 Share Posted April 2, 2006 i'm very interested in this.. where did you source the EDIS 36-1 wheel from and also, where did you get the coil pack!! When i swap in the new motor i might consider EDIS =) Quote Link to comment Share on other sites More sharing options...
510six Posted April 2, 2006 Author Share Posted April 2, 2006 http://home.earthlink.net/~beanbooger/boost_engineering/ Was the source for the 36-1 wheel, very easy guy to work with.I Ebayed the 90 Ford TBird SC coilpack connector and mount for less than $40. The 36-1 wheel was mounted using four tapered 6mm allen machine screws with the wheel modified to almost press fit on the ATI dampner .It`s very important to get the -1 tooth in the correct position before any holes are drilled.The AEM EMS uses sequential injection up to 2000rpm so a cam position sensor is used for injector/spark timing.The cam position sensor is a modified 81 turbo dist. with a Ford VR sensor mounted inside an aluminum cap covers the works up. http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=63ef&.dnm=b32a.jpg&.src=ph Quote Link to comment Share on other sites More sharing options...
pete280z Posted April 2, 2006 Share Posted April 2, 2006 Thanks for the info. Mounting the 36-1 like that looks like a very good idea to me. I'll take another look at those ATI dampers. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted April 9, 2006 Share Posted April 9, 2006 vr sensor was from a 2005 4.0 v6 mustang cam position sensor-510six has an inside connection for ford parts Quote Link to comment Share on other sites More sharing options...
510six Posted April 9, 2006 Author Share Posted April 9, 2006 LOL...thanks Quote Link to comment Share on other sites More sharing options...
