driveshaft to q45 diff bolts
nazar
Finishing up my rear end and cant figure out where to get the bolts to hold the flanges together
i know i need just enough smoothness to span the thickness of both flanges and not too much thread to where its too long
what have you guys used?? What size bolt? Strength?
I assume i can use stock q45 bolts but where can i get them? Can i order those from infinity? Since my flange and diff are identical those should work best??
grade 8.8 metric should be the most common out there. grade 10.9 is a bit harder to find but is quite a bit stronger.
i'd actually search around your area in the yellowbook under fasteners. that's the best way to find nut/bolt specific companies. they're always listed under fasteners.
