rustorbust Posted April 4, 2006 Share Posted April 4, 2006 Im putting together a small block chevy for my 72 Z and a buddy of mine gave me an oil pan and pump setup. Its a B&B P/N 128-91088 I beleive it says that the sump is 8" long, will the clear the front crossmember underneith the motor if I am usuing the JTR kit? Thanks Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted April 4, 2006 Share Posted April 4, 2006 Im putting together a small block chevy for my 72 Z and a buddy of mine gave me an oil pan and pump setup. Its a B&B P/N 128-91088 I beleive it says that the sump is 8" long' date=' will the clear the front crossmember underneith the motor if I am usuing the JTR kit?Thanks[/quote'] That pan actually has a 8" DEEP pan. You have to be concerned with the front portion of the pan for fitment with the crossmember. I'm using the Moroso 20190 kickout pan with 8.25 sump. My engine sits low and equivalent to the JTR position with the crossmember lowering spacers. There is plenty of clearance for the front of the pan with the crossmember. However, I must jack up the engine in order to remove and lower the oil pan. Hanns Quote Link to comment Share on other sites More sharing options...
rustorbust Posted April 4, 2006 Author Share Posted April 4, 2006 Sounds good, Thanks Quote Link to comment Share on other sites More sharing options...
