Backfire and run-on
rclayton12
I have a '73 240z that I have just converted from the flat top carbs, to Ztherapy S.U.s and after I drive the car for about 20 minutes, it will backfire, and run a little while after I have turned the key off I think it is called Diesel-ing. I had the same problem with the flat tops, and was hoping that the S.U.s would fix it. Any help would be appreciated.
Guest beandip
I agree with rclayton12 . In addition ZT often installs SM needles check to see if this is the case . If so buy a set of 54s , SMs are way to rich and this could cause what you are describing . Also double check the timing and set a 10 degrees BTDC . If the timing is retarded it also will cause the described problem .
