Target AFR tables
blake culp
I have my target AFR tables set, and the megasquirt seems to be using them with no problem but how exactally do i set my VE table so it matches my target table. The way it is running now on just the target tables i would always have to have the wideband on the car, and if the wideband went bad im sure some bad things would happen to my motor.
Thanks,
Blake
The manual way would be to log the percent correction on a drive then analyze the file at home and re-adjust accordingly the target values that required a large percent correction during the drive. There should be software to automatically update like mentioned, but I haven't chekced into it yet.
