Wondering Nomad Posted April 15, 2006 Share Posted April 15, 2006 Would this check valve work to vent the fumes from the tank? If I blocked off all the lines and ran one line into the fender well with this on it...thoughts? Check Valve Quote Link to comment Share on other sites More sharing options...
2126 Posted April 18, 2006 Share Posted April 18, 2006 Something to think about! As you know, a check valve allows flow in only one direction. If installed to allow air flow into the tank, which is the way I would assume you are installing it, then it will certainly prevent the tank from collapsing.....but what about when the car is not running and its a pretty hot day.....what then happens as the fuel/fumes expand? Quote Link to comment Share on other sites More sharing options...
