Bartman Posted April 21, 2006 Share Posted April 21, 2006 Here's a picture from a while back that shows how my radiator is placed. Since this picture I've added sheet metal between the radiator support and the radiator to ensure that the air coming through the support goes through the radiator. I also have a condensor mounted to the front of the radiator support. I'm currently using a Taurus fan wired up normally on the engine side of the radiator, but I'd like to move it to different location. My options are to mount the fan to the front of the condensor or the front of the radiator as a pusher, or to the back of the condensor (wired normally as a puller). I assume I only have to reverse my wiring to make the fan a pusher and that it will be a little less efficient, but I'm thinking it will still be moving plenty of air. If the fan is between the condensor and radiator it would be hidden by the shrouding and would look nice and clean. Here's a pic with the fan mounted on the engine side and the shrouding in place. So what do you think? Quote Link to comment Share on other sites More sharing options...
