JaysZ Posted April 26, 2006 Share Posted April 26, 2006 I'm trying to remove my air con unit in its entirety. So far, with the dash gone, I was only able to remove the blower and a few other small pieces. The main thing is in the center which have copper tubes coming from the engine bay. I can't seem to unscrew anything that will allow me to remove it without cutting. I'd like to keep this in decent condition for resale. Is it even worth anything to scrap or should I just cut it out? Anyone else remove theirs? Here are some pictures, thank you in advance! Quote Link to comment Share on other sites More sharing options...
spotfitz Posted April 26, 2006 Share Posted April 26, 2006 Look at the front just below the controls and you will see two bolts. Then get in the engine bay and you will see two nuts on studs coming through the fire wall. Pull the grommet cover off the grommets around the copper lines and the other for the heater lines and pull the grommets out. It should come loose then. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted April 27, 2006 Author Share Posted April 27, 2006 thanks i will try that =) Quote Link to comment Share on other sites More sharing options...
JaysZ Posted May 1, 2006 Author Share Posted May 1, 2006 i finally got it =) thanks for the tip! now i need to buy an angled screw driver to get those stupid defrosting vents out :/ Quote Link to comment Share on other sites More sharing options...
