280zxt, replace lines with steel braided q's
zxgtr
Ok all, I've finally gotten back around to working on my project zxt, while most of my stuff is already fitted and ready to go I am in the processes of cleaning out the engine bay and removing most of the stock 280zxt items as they no longer surfice to my needs.
I currently am trying to replace the following lines:
A) Oil cooler: 18mm to 10AN adapter -> 10AN hose w/ 3/8 hose end for the after market cooler
B) Trans mission cooler, I need to find out the sizes for the transmission, guessing (havent looked) its a 10x1.5, would a banjo fitting be good or a 90 degree AN fitting with the metric adapter?
C) Power stearing lines, from the couplers to the pump, nothing else, just need the right size (looks like the 18mm).
Any suggestions on a-c would be great, looking for sizes and recomendations, goal is not to cut/weld anything but use adapters. I'd also like input on the best way to convert these sizes, the oil/trans cooler uses 3/8NPT fittings so all hose can be 3/8" but that has to fit into the 18mm and 10?mm mounts some how.
Once I get a solid parts list ill post the total thing with prices, guessing its going to be around $200 for the lines and fittings, add $180 for the dual cooler.
