Bogging and Pigtails on T.V.S's, whats the deal?
I have noticed on random occasions that my 300zx will start bogging down by itself and I have to keep 1 foot on the brake and 1 on the gas to keep it idleing. I noticed that when I wiggled the TVS connector, the car would idle again, but the connector is so loose. any ways, I have my 5spd in the shed and it came with the Throttle Valve Switch for a manual, so I put that one on and my Z idles really nice now, but I have to wonder what that pigtail connects to off of the automatic version one. Do you think I will be ok driving without it connected? Does anyone know where that connector leads?
Guest ZFury
The second connector is for the automatic as you have said. It is a for the poto (poto is short for something I cant spell) TPS sensor part. The manual TPS is like an on/off switch, while the automotics poto sensor gives the exact position of the throttle. Like if your at 10%, 25% or 90% throttle. You can put a automatics tps on a manual car, but the second plug should do nothing. I leave mine unpluged just it case it does do sumtin'.
On an automatic TPS, the pigtail is typically the kickdown for the auto tranny.
The kickdown is an on/off switch. It tells the transmission to shift down a gear when you go near full throttle. (for passing or quick acceleration)
TPS is used by just about every EFI engine, regardless of transmission type, and is a potentiometer (or reostat) which varies in resistance according to throttle position. The ECU knows how to compensate for throttle changes by how the TPS signal changes. (ie: you punch the gas, and the computer knows to dump a little extra fuel to compensate for the surge of air thats coming)
The manual TPS should work as a potentiometer, not a switch.
Guest ZFury
The manual TPS should work as a potentiometer' date=' not a switch.[/quote']
I was told different. Because when you want to use an after market ECU or piggy-back ECU you have to get a TPS from an automatic and use the extra connector for the TPS connection for the after market ECU. I could have it mixed up though... But you can have the car running and twist the TPS and it wont do anything on a manual.
Zfury is correct. The Nissan ECCS uses a idle switch for the EFI and a pot for the transmission control. The connector on the pigtail is for the pot. You can use it for standalone TPS information. Some of the units also have a full throttle switch, but I don't think that the 300zx uses this input.
The ECCS uses mass airflow and rpm, among other inputs, to calculate load instead of TPS, same as the Jetronic on the early cars.
Doug
