Would these wheels fit?
The backspacing needs to be more like 149mm, or 22mm offset (toward the outside of the wheel) for a 17x9 wheel to fit with coilovers. Note that this is with a Wilwood rotor hat that is 1/2" thick at the wheel mating surface, so for a stock drum, you'd need more offset or a spacer. Check "wheels & tires" on my site (below)
Pete Paraska - 73 540Z - Marathon Z Project - pparaska@tidalwave.net">pparaska@tidalwave.net -
  • 5 months later...
Looking for clarity on this whole wheel fitment thing:
Pete's statement doesn't make sense to me. If a drum is used instead of the special disk brake hat, wouldn't that mean that less wheel offset sould be required?
IE, for 1/2" less "hub", you would then need 1/2" (12mm) less offset for a net of 10mm wheel offset, or else a 10mm spacer.
Not trying to be difficult, I'm just very confused (took about an hour of contemplation to understand backspace vs. offset) and I need to understand the wheel fitment requirements for the 240.
