Rumnhammer Posted May 14, 2006 Share Posted May 14, 2006 Hi all, I tryed the search and came up empty so I'll throw this question out there. I know that the clutch for the Rb25DET is the same as the 240mm N/A 300zx, but what throwout bearing is used? same one as the N/A 300zx, turbo? anybody know? Chris Rummel Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 14, 2006 Share Posted May 14, 2006 The turbo and N/A are the same bearing, According to race bread http://racebread.com/smf/index.php?topic=395.0 and will work with RB series engine/trannies. Also the pilot bushing is the same as the VG30. Hope this helped you out! Quote Link to comment Share on other sites More sharing options...
Rumnhammer Posted May 15, 2006 Author Share Posted May 15, 2006 yeah, sure did I'll just tell my friend to get the ACT kit for the N/A Z32 if it comes with the throwout bearing.... Thanks for the help. Chris Rummel Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 16, 2006 Share Posted May 16, 2006 yeah' date=' sure did I'll just tell my friend to get the ACT kit for the N/A Z32 if it comes with the throwout bearing....Thanks for the help. Chris Rummel [/quote'] Whatever you do bro, make sure that the throwout bearing has enough clearance to reach the pressure plate (get the right clutch collar and bearing). Also compare the two pressure plates and check if the contact face (where the bearing hits the pressure plate) for the Z32 N/A is shorter or not, for some reason, I got my Z32 N/A clutch kit from ACT and my release bearing was short and I had to put on a spacer. For some reason my whole setup didn't work and that's why I had to put the spacer in to make sure the bearing reached the pressure plate (also cost me $200 bucks in labor from a friend's shop to drop the trans down to find the problem). Also, the OEM style T/O bearings are better than the aftermarket ones that ACT provides in the kit. If I had to do it over (on my next clutch job) I would definately throw out the ACT T/O bearing that came with the kit and get the Nissan one, I can provide a part number if you need it. -Q Quote Link to comment Share on other sites More sharing options...
Rumnhammer Posted May 17, 2006 Author Share Posted May 17, 2006 yes please........ chris:burnout: Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 17, 2006 Share Posted May 17, 2006 yes please........chris:burnout: Oh yeah, I get ACT Flywheels @ Wholesale. Quote Link to comment Share on other sites More sharing options...
Rumnhammer Posted May 17, 2006 Author Share Posted May 17, 2006 How much for this clutch? My friend is getting ready to buy one, maybe you can save him some cash. Chris Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 17, 2006 Share Posted May 17, 2006 How much for this clutch? My friend is getting ready to buy one' date=' maybe you can save him some cash.Chris[/quote'] I have to check the part number and let you know tommorow. Quote Link to comment Share on other sites More sharing options...
