Another BOV question.
OK, I have disconnected the mbc. I have replaced the Freddy BOV with another Freddy. I believe that the problem is the BOV. I believe it is leaking boost at 7-9 psi. Apparently this is very common with that BOV. My boost is getting to 7-10 psi, falling or stalling for 2 seconds, then spooling up but only as a factor of rpm. I figure it is still leaking, the GT2871R just puts out enough air to continue for the boost to increase. The rest of the piping does not appear to leak. Also, if there was a leak in the rest of the piping, the boost probably would not increase after stalling. Is my reasoning correct?
Should I just fork out the dough and get the HKS SSQV with recirculation kit?
Does it work reliably? I plan on running 17psi for daily driving.
