caen fred Posted May 16, 2006 Share Posted May 16, 2006 My car has a strange behaviour! It’s for my 1983 280ZX Euro type Start fine, run fine… but start acting when hot… cannot take it’s rpm but idle fine I have checked the plugs, all the connexions, and all the potentials air leaks nada de nada!!!!! But if I unplug the water sensor… the car runs fine… Must be on the SAFE mode on the calculator but then wouldn’t it run at */- 1200 rpm instead of the 800 rpm it shows????? Help me please Quote Link to comment Share on other sites More sharing options...
MatMan Posted May 16, 2006 Share Posted May 16, 2006 might try this thread: http://forums.hybridz.org/showthread.php?t=109201&highlight=temp+sensor or search for "Won't rev" or try this one: http://forums.hybridz.org/showthread.php?t=79852 Quote Link to comment Share on other sites More sharing options...
caen fred Posted May 17, 2006 Author Share Posted May 17, 2006 Took a reading our of the temp sensor... Cold 1.66 Hot 0.30 I don't have my Haynes with me... is it in spec.? Thanks Fred Quote Link to comment Share on other sites More sharing options...
caen fred Posted May 24, 2006 Author Share Posted May 24, 2006 any more ideas... summer is here and I would like to use the beast Quote Link to comment Share on other sites More sharing options...
caen fred Posted May 26, 2006 Author Share Posted May 26, 2006 Worse and worse, or maybe... Now it's the battery that doesn't charge enough, so it caugh, then the wipers go on????????? and it dies! If you plug a booster everything goes well, then after a while caugh, wipers... Could it be a faulty regulator? Could all this be related to the alternator???? The car is sold, so I must fix it ASAP or I will have to give the cash back Quote Link to comment Share on other sites More sharing options...
caen fred Posted May 29, 2006 Author Share Posted May 29, 2006 Nothing????? If you cannot give me hand... maybe a finger? Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted May 30, 2006 Share Posted May 30, 2006 Now it's the battery that doesn't charge enough Just trying to help... a fuel injected car runs like crap with a bad battery. Mine ran much better once I got the charging system working properly. (first step in getting charging system working = good battery) Quote Link to comment Share on other sites More sharing options...
caen fred Posted May 31, 2006 Author Share Posted May 31, 2006 Thanks, I will try with a good alternator... the battery is OK Quote Link to comment Share on other sites More sharing options...
