Guest 86300ZXT Posted May 25, 2006 Share Posted May 25, 2006 Does anyone know what size intercooler I should run in my 86 300zxt? Thanks Quote Link to comment Share on other sites More sharing options...
Guest ZFury Posted May 27, 2006 Share Posted May 27, 2006 The largest one with 3" piping you can fit in it... Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted June 2, 2006 Share Posted June 2, 2006 most of the setups out there are running 2.25in inlet/outlet on the I/C's. Here is a good link to some pics and details... http://www.redz31.com/turbofaq/intercoolers.html Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted June 6, 2006 Share Posted June 6, 2006 A quality bar and plate design, with a thickness of no more than 3", decent endtanks on the longest/tallest core you can find. Quote Link to comment Share on other sites More sharing options...
mtcookson Posted June 6, 2006 Share Posted June 6, 2006 I wouldn't go any larger than a 2.5 inch inlet and outlet unless you're running some extreme power. 3 inches is starting to get on the overkill side and even to the point where you wouldn't make the power you would with 2.5". The largest one with 3" piping you can fit in it... If you'd like to lose some power and increase lag do this. Quote Link to comment Share on other sites More sharing options...
Guest Jason84NA-T Posted June 7, 2006 Share Posted June 7, 2006 Anything that has good efficiency and low pressure drop at 800+CFM. No bigger than 2.5" inlet/outlet or piping. If they don't publish the flow and efficiency ratings, it's not worth buying. Quote Link to comment Share on other sites More sharing options...
