best clutches
My combination is set-up for autocross, so I don't use drag slicks. My car weighs 2700 full of fuel with me in it, and has ~320 hp at the rear wheels. I am using the king Cobra clutch disk and pressure plate. I have had no troubles with clutch slippage since I installed it.
I don't know how this clutch would perform under hard launches with drag slicks, but for me it works well.
My pedal is fairly light, and the clutch disengages about halfway through the pedal throw. I have a Wildwood 7/8" clutch master cylinder and a Tilton hydraulic throw out bearing.
The details of my clutch set-up are in some of my older posts like this one:
http://forums.hybridz.org/showthread.php?t=87797&highlight=clutch
sweet thx mate.
because i'm using a tr3650 gearbox out of a ford falcon xr8 (i think it's also in the new mustang 5spd). I need a xr8 clutch disc with a 5.0L clutch housing (possibly king cobra). I no that this is a bit queer but aparently the input splines between the t5 and tr3650 (although have the same diameter and amount of splines) aren't the same.
