Guest Anonymous Posted January 25, 2001 Share Posted January 25, 2001 Are the rear struts all the same? ie. if I had a 260 or a 280 rear strut to test the brake fitment on, would it for sure work on my 240? Don't have a spare 240 strut in a convient junkyard, just 280 ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
pparaska Posted January 25, 2001 Share Posted January 25, 2001 I don't know for sure, but I'm 99% sure that dimension is the same. I think all the differences are in the strut tube. I believe the casting below the tube is the same part(s). Quote Link to comment Share on other sites More sharing options...
Guest scca Posted January 25, 2001 Share Posted January 25, 2001 they are the same for that dimension you need morgan.. all others are different as Pete has mentioned Mike Quote Link to comment Share on other sites More sharing options...
pparaska Posted January 26, 2001 Share Posted January 26, 2001 260 and 280 struts are different in several ways. Tube diameter and gland nut is one difference, height of tube may be another. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 26, 2001 Share Posted January 26, 2001 Well, what about as far as brakes go? The offset from the caliper/drum mounting face to the hub surface the drum/rotor sits on - is it the same? Stuff like that..... ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
