JustinOlson Posted June 1, 2006 Share Posted June 1, 2006 I'm looking at doing a twin turbo setup much like this picture for my Z. I'm wondering if these truck manifolds would clear the frame rails? Regards, Justin Quote Link to comment Share on other sites More sharing options...
BringIt Posted June 2, 2006 Share Posted June 2, 2006 I will let you know in the next few weeks. It is looking good I did a test fit without the mounts (Motor was in the car) and it looks like it will fit. Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted June 2, 2006 Author Share Posted June 2, 2006 Very Nice! This looks like a very effective way to do a budget single or twin setup on the LS motors. Please take pictures when you test fit the headers. Regards, Justin Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted June 2, 2006 Share Posted June 2, 2006 Just FYI, to do this you need to use the 6.0 Truck Manifolds. I think it would be cool to do, I think the problems that you'll run into is the steering column on the driver's side. There is a lot of info LS1tech.com about these type of setups. Tyson Quote Link to comment Share on other sites More sharing options...
BringIt Posted June 2, 2006 Share Posted June 2, 2006 actually the 4.8, 5.3, and 6.0 Manifolds are all the same. But I did get some for a 03 Silverado SS though. The only problem I see ( If the motor was sitting almost in the right spot ) was the flange hitting the framerail. I'll just have to grind/mill off the flange and weld a piping extension to it. Was considering doing that anyway so that I could use V-band Clamps for the Y-Pipe. I'll be going Single Ive got 3 manifold sets here. 98 stock f-body manifolds - 05 GTO 6.0 Manifolds - and 6.0 Truck Manifolds. I'll get one of them to work and let you guys know. Quote Link to comment Share on other sites More sharing options...
