horishima Posted June 7, 2006 Share Posted June 7, 2006 Does anyone know if the 200sx turbo R200 has a stock LSD I know its a 4:11? #38300-76S00 Thanks Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 7, 2006 Share Posted June 7, 2006 no it does not come with a factory LSD. The only r200 long nose in the US that came with factory LSD was the 300zx turbo from 87-89 and that was a 3.70 ratio Quote Link to comment Share on other sites More sharing options...
horishima Posted June 7, 2006 Author Share Posted June 7, 2006 Thanks Quote Link to comment Share on other sites More sharing options...
horishima Posted June 15, 2006 Author Share Posted June 15, 2006 I found one now do I need a mustach bar from a 280, and is there anything else beside CV axles, and a LSD that I should need? Anyone recommend a LSD Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 15, 2006 Share Posted June 15, 2006 yes you need the r200 mustache bar from a 280z. As far as LSD goes you can either do the Nismo 2way, or the Kaaz 2way which has more clutch discs than the Nismo unit. Quote Link to comment Share on other sites More sharing options...
fastzcars Posted June 15, 2006 Share Posted June 15, 2006 You also have PG Power Brute and Quaife for LSD's. Quote Link to comment Share on other sites More sharing options...
horishima Posted June 16, 2006 Author Share Posted June 16, 2006 Thanks again guys Quote Link to comment Share on other sites More sharing options...
horishima Posted June 22, 2006 Author Share Posted June 22, 2006 Hey guys the person with a diff is telling me its an lsd because he was turning the axles and they turn the same way. How can I make sure its a 4:11 and with an LSD what should I look for. Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted June 22, 2006 Share Posted June 22, 2006 If turning isn't good enough for you have him pull the rear cover, take a pic and the clutch packs will be very easy to spot. Quote Link to comment Share on other sites More sharing options...
olie05 Posted June 22, 2006 Share Posted June 22, 2006 Hey guys the person with a diff is telling me its an lsd because he was turning the axles and they turn the same way. How can I make sure its a 4:11 and with an LSD what should I look for. first off, its "4.11:1", secondly, if you pull of the cover, there will be a marking... like 39/11(3.5454:1) or 39/10(3.9:1)... not sure which it is for 4.11:1, but if you devide the top number by the bottom number you get the ratio. This will be printed on the Big gear that will be poking out, just turn to find it. or you can turn the input shaft and count how much the output shafts turn, but this will not be a very good way of getting exact ratios... ex. you have 3.54, 3.7, 3.9 and 4.11 to choose from (common ratios) Quote Link to comment Share on other sites More sharing options...
Mack Posted June 22, 2006 Share Posted June 22, 2006 the ratio on a 4.11 should be 37:9. as far as LSD, i wouldnt trust the "jack the car up and spin the wheel method". someone once explained to me that worn spider gears could cause an open diff to behave like an LSD. I cant remember how, but it does. best to get pics of the clutch packs. Quote Link to comment Share on other sites More sharing options...
horishima Posted June 22, 2006 Author Share Posted June 22, 2006 Thanks alot guys Alex told me he got burned once by a ebay deal... Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 22, 2006 Share Posted June 22, 2006 yea like i said, have him open the rear cover, if he has nothing to hide then he should open it no problem Quote Link to comment Share on other sites More sharing options...
driftz240 Posted June 22, 2006 Share Posted June 22, 2006 s12 silvia rs-x came with a fj20et with 210 hp and a r200 with lsd and cv axels, it also bolts into the 240-280z with a 280z mustache bar. and the cv axels are the exact same part as the 280zxt cv axels.. my diff came from okinawa japan from a friends car, it was a rs-x, those cars are wicked fast. with bolt ons you can get a 300hp s12...thats also indistructable.... so i belive the rs-x was avalble from 86-88... they had a 2 way clutch type diff in them, and were 4.11 gear. i have the diff he brought back from japan, and it now has a newer nismo gtlsd in it .. Quote Link to comment Share on other sites More sharing options...
