compression ratio wiith vg30dett pistons?
randy 77zt
from what i have heard if you bore out a l24 rod 1mm on the small end and run a ld28 crank you can use these pistons.i got a free set .the piston has a roughly 9cc dish-i measured it with a syringe and soapy water.what would compression ratio be with p90 head?bore size is 86.5 mm
still need the pin height to calculate everything.
Edit:
I got a pin height of 31.75mm... is that correct?
with that pin height, and ozdats online calculator:
2.927 litres
7.236 static cr
with a 1mm head gasket
I thought VG pistons start at 87mm?
With VG30E(I know it's not vg30dett) you get 21mm pin size and 1cc of dish, dunno about ET tho. If boring & honing out six rods cost as much as getting VG30E pistons then they are about the same cost-wise. Just throwing it out there in case you have second thoughts.
