HEI with Crane XR700
I don't see why that wouldn't work, I guess if I was worried about hurting the crane unit, I would make a quick test setup using 12 volts and a toggle switch to fire an HEI module and make sure it works at least manually, one spark at a time, use a current limiting resistor for the test setup (like the schematic in the install guide shows for megasquirt triggering the HEI module).
Also, the HEI module rpm limit is higher on a 6 cylinder than 8 cylinder, see my reply over on zcar.com
