Camber Problem
Guest dherde26
Guest dherde26
OK, so guys I drive a 77 280z and I have a problem with the camber on the left front...i was messin around on a down hill hairpin and lost the *** end and the front end snapped around and hit the curb on the same side of the road.
after this i noticed that the front left was heavily posotive cambered
so i started looking at the components...i checked the lca's and the t/c rods and the mounts for the t/c rods both seemed strate in comparison with the rite front and the only thing i could find was the crossmember had some waves in it so i changed that out..which helped a little but idk what else to check
is it possible for the spindle to bend???
any input would be greatly apreciated
thanks
drew
Guest dherde26
the entire strut can bend... right at the bottom where it is welded to the lower casting... it can pop the weld as well...
an IT cheater trick was to bend them slightly for more negative camber.
never thought about that
thanks
