Caster Question
Guest Anonymous
Guest Anonymous
Everyone,
Please help me out. What is the prefered alignment specs on a 73z front and rear? That is if it was adjustable. To add pos. caster would you want to move the lower control arm forward?
Thanks in advance,
Glenn
I never payed any attention to rear caster specs because it really does not matter (IMHO). The front is a different story though. I believe the front should be 3 degrees. Arm (axle) forward will make it more positive (and I might add, will give interesting results as far as wheel turn angle vs negative camber).
Terry Oxandale
Guest Anonymous
Terry, Thanks for your answer. Forward movement of the control arm for more + caster is what I thought I remembered from school. When I refered to the rears I meant toe & camber. Also what camber & toe specs are the best for the front. Note my car will see hard street driving with some track time (maybe).
Thanks,
Glenn
