Brakes
Guest EPS
I've seen the 79-81 master cylinder used on early models. Mine is 78. Is there an advantage since mine is already two resevoirs? Also the 2+2 brake vac is suppose to lessen brake effort by about 25%.
Can this be a "bolt up?" Dealers and some Z guys don't have a clue. Any suggestions always appreciated. THX!
This is supposed to be a bolt-on operation. There was a thread a while back and someone had done this with no problems whatsoever.
Ah, here is what the JTR manual has to say:
"The power brake booster from a 280Z 2+2 is larger than the 2 passenger Z car and offers about 30% more hydraulic pressure for a given pedal pressure. This unit will not fit in the earlier 240Z cars because the clutch master cylinder is positioned too close to the power brake booster. If you are using an automatic transmission, there is no clearance problem."
So, if you can even do this depends on which tranny you use. Hope this helps smile.gif
David
SCCA kind'a hit it where I was thinking. Unless you have larger pistons on the calipers (or greater total piston area for multi-piston calipers) you will reduce the amount of leverage (master cylinder piston area:caliper piston area being increased)you have for brake pressure. Sure, the pedal will feel firmer, put that is because you will have the reduced leverage ( increased the resistance). The reverse is true for those that put larger piston calipers on, without increasing the master cylinder piston area. The leverage increases and they will get excellent pressure to the calipers, but the pedal will feel a bit mushy. The key is to balance out the system. The OEM system is pretty good, so if you can keep the ratio of master:caliper close to OEM, you will keep the OEM "feel".
And as my wife would say..blaa blaa blaa blaa blaa.
Terry
most aftermarket master are the same bolt pattern but not a dual reservoir. so not safe unless youuse 2 separate masters and a balance bar-- not needed for street use..
one of my other back projects was to use a z32 or 240sx master that bolts on reversed pattern and figure out the spacing to use it on a earlyZ .. the 300 are 1&1/16" so larger than the 280zx...
a 15/16 is more than sufficent.. for the street but larger always looks better...
Mike
