Guest 350man Posted June 22, 2006 Share Posted June 22, 2006 i'm installing a new cam and a gear drive. got te gear drive off a friend but no instructions. he kinda told me what to do but he couldn't remember. its a pete jackson noisy gear dive. does i need to know if #1 tdc and how to know if the cam is in the right position? i'm still a little new at rebuilding motors Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 22, 2006 Share Posted June 22, 2006 i'm installing a new cam and a gear drive. got te gear drive off a friend but no instructions. he kinda told me what to do but he couldn't remember. its a pete jackson noisy gear dive. does i need to know if #1 tdc and how to know if the cam is in the right position? i'm still a little new at rebuilding motors The gear drive is the same ans most timing chains. Has a dot on the cam gear and one on the drive gear. There should be a copper spacer to go underneath the cam gear inbetween the block. If you want it to last get a big block cam oil galley pipe plug, they have a small oil hole in it that will spray oil on the back of the cam gear and keep it all well lubed. Put it in the center (main/rod/cam) oil galley. The two dots have to line up with the cam at the 6 o'clock position and the crank at the 12 o'clock position, then the idler gears go in and you check cam timing. Degreeing is handled by offset bushings on the cam, hopefully you got those and the lock plate that goes underneath the bolts, holds the bushings in and also if your using a roller cam you'll want to use a thrust button or bearing there. There are several types of those, roller bearing, aluminum and plastic. Stay away from the plastic, they don't live very long. When you get it degreed, put the lock plate under the bolts, torque (25 ft-lb i think) and then bend the lock tabs over the sides and top of the bolt. If the lock plate is used, you might want to get a new one at autozone or something, they sell them, otherwise the tabs may break off. The idler gears have a pointed end on the shafts, that goes towards the block. Sometime the block casting numbers have to be ground off in the area that it rests so that it goes in all the way, depends on brand though. If your block has been line honed or bored you may find that a gear drive wont' work, they make one for that application, at least I think pete jackson, moroso and cloyes do. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 23, 2006 Share Posted June 23, 2006 Doc, you forgot to mention the middle gears and how they go in: one is slightly bigger than the other! The larger of the middle gears goes on the...right or left? Davy Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 23, 2006 Share Posted June 23, 2006 Doc' date=' you forgot to mention the middle gears and how they go in: one is slightly bigger than the other! The larger of the middle gears goes on the...right or left? Davy[/quote'] Doesn't matter, as long as the pointed end of the shafts goes towards the block. Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted June 23, 2006 Share Posted June 23, 2006 I bought a Dynadrive (dog bone style like Pete Jackson's) gear drive, and it came with a cam button and a lock plate as well as the brass cam to block thrust washer dr_hunt mentioned. The instructions state that the dog bone must be positioned with the larger idler gear on the left (viewed facing the engine, so this would be on the passenger side of the car). They call that the 'power idler', and the little one is called the 'reverse idler'... it only comes into play under deceleration; it keeps the engine from spitting out the power transferring idler. "Reverse idler (small gear) should have free vertical movement of .005" to .075" when drive idler gear is in solid mesh with cam and crank gears". "Put idler gears about half way in, then install cover (with gasket) and push into place. Remove cover and that is where the idler assembly will run. The chamfered end of the power idler must not touch block. Grind off if necessary for at least .005" end clearance." Their illustration shows a range of .005 to .075" and notes the clearance may be checked with putty. It would be good to always use the same thickness cover gasket & be sure that compressing it still leaves the minimum .005". "DO NOT TRAP AXLES between the block and front cover." There are two different length Chevy torrington bearing cam buttons on the market that I know of. I think the longer one fits the timing chain covers with a raised circle in the center with 3 spokes off it, and the other fits... the other style Chev timing cover. My instructions suggest .005 to .010 end thrust on the camshaft, grind the face end of the cam button to get it. I bought an aluminum Edelbrock water pump that has incorporated an adjustable thrust stop into the design. Busy finishing off a house, so I can't say how well it works, but seems like a good idea. If you want to install your cam with some additional advance, the thicker part of the chosen offset bushing goes to the left; to retard a cam, turn bushing 180 degrees... face the thick part to the right. I know that flat tappet cams have a taper that is supposed to keep the cam from walking, but I plan to run a button, and have drilled a valley plug for oiling. I'm not running a computer (gear noise has been known to screw up knock sensors) and like the longevity of gears. Good luck, hope you like your drive. . Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 24, 2006 Share Posted June 24, 2006 Doesn't matter, as long as the pointed end of the shafts goes towards the block. Hmm, I just read somewhere in CarCraft of Hot Rod, one of the magazines out there, that it does make a difference. I was hoping you had read the same thing and would tell me too since my gear drive didn't come with any instructions either! LOL Well, maybe there is no difference... Davy Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted June 25, 2006 Share Posted June 25, 2006 Davy, here's a kit (from Jegs site) that might be useful if you picked up a used 'Pete Jackson'... _________________________________________________________________ Chevy Installation Kit 782-327-21 Gear Drive Installation Kit # IncludesThrust Button Assembly # Offset Bushings(set of 5) # Lock Plate # 3 Bolts & Washers $31.99 _________________________________________________________________ I think I have a .pdf file of the instructions for a Jegs dogbone style drive somewhere if you'd like a copy... (most everything should be in my post above, but one never knows). . Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 26, 2006 Share Posted June 26, 2006 Davy' date=' here's a kit (from Jegs site) that might be useful if you picked up a used 'Pete Jackson'... _________________________________________________________________ Chevy Installation Kit 782-327-21 Gear Drive Installation Kit # IncludesThrust Button Assembly # Offset Bushings(set of 5) # Lock Plate # 3 Bolts & Washers $31.99 _________________________________________________________________ I think I have a .pdf file of the instructions for a Jegs dogbone style drive somewhere if you'd like a copy... (most everything should be in my post above, but one never knows). .[/quote'] Thanks A.G.! Yeah, I'll take install instructions if you have them--just email or PM me---many thanks! I'll end up having to buy that install kit for certain from Jegs. Thanks for the link. Davy Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 26, 2006 Share Posted June 26, 2006 Thanks A.G.! Yeah' date=' I'll take install instructions if you have them--just email or PM me---many thanks! I'll end up having to buy that install kit for certain from Jegs. Thanks for the link. Davy[/quote'] Davy, I think I have what you need NIB. Let me check, if I have it I can mail it to you today. Doc Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 26, 2006 Share Posted June 26, 2006 Depends on the gear drive, on mine, all 3, the pointed end is on one shaft only, anyway if you put it in wrong on mine anyway you can't get the timing cover to fit flush, which puts the big gear on the left side as your facing the block. That's the way mine are anyway. I have a tope gear, idler gears, thrust washer, roller cam thrust button, cam lock plate NIB if you need it. It came without the crank gear and they just sent me a new one. Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted June 27, 2006 Share Posted June 27, 2006 Thanks A.G.! Yeah, I'll take install instructions if you have them--just email or PM me Davy: I logged on and tried to email you through your screen name, but the board says I don't have permission. I then tried a PM, but don't see a way to attach a file. Damned computers:icon45:. . Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 27, 2006 Share Posted June 27, 2006 Davy: I logged on and tried to email you through your screen name, but the board says I don't have permission. I then tried a PM, but don't see a way to attach a file. Damned computers:icon45:. . Just send it via davyZ@hybridz.org which should work. Thanks! Also, Dr Hunt, thanks for the parts!!! This weekend is fine by me--I'm in no hurry right now. Good to have friends on the board Davy Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted June 27, 2006 Share Posted June 27, 2006 Just send it via davyZ@hybridz.org[/email'] which should work... failure notice Hi. This is the qmail-send program. I'm afraid I wasn't able to deliver your message to the following addresses. This is a permanent error; I've given up. Sorry it didn't work out. : 68.224.171.74 does not like recipient. Remote host said: 550 unknown user Giving up on 68.224.171.74. . Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 28, 2006 Share Posted June 28, 2006 Wow, I wonder if SuperDan has suspended my email or something, lol. Please see my PM to you with alternate email. If that does not work, I'm SOL. Thanks for trying yet again... Davy Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted June 28, 2006 Share Posted June 28, 2006 OK, will do. Here's a link to another set- http://www.compcams.com/Technical/Instructions/Files/117.pdf . Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 28, 2006 Share Posted June 28, 2006 Got both, thanks! Davy Quote Link to comment Share on other sites More sharing options...
