Thumper Posted June 30, 2006 Share Posted June 30, 2006 Just got my new project up and running; with details and pics soon to be posted. It is a 280zx n/a non-digital dash running megasquirt and msd 6al. Everything is working to plan except I have no tachometer. I have hooked both the tach output on the msd and 4 other wires coming out of the stock wiring loom to every possible combination with the same wires wire with some sweet sparks to boot. I have hooked up the black/white wire to the - and + terminal on coil, the blue wire, white wire, etc... I think what I'll end up doing is running the tach output wire on the msd to the correct wire right behind instrument cluster. I have never had much luck with wiring diagrams so does anybody know what color and where I can find this wire or did I not try something earlier that should make it work? Thanks Quote Link to comment Share on other sites More sharing options...
DemonZ Posted June 30, 2006 Share Posted June 30, 2006 I'm taking a wild stab here, I think you need a "tach convertor". Quote Link to comment Share on other sites More sharing options...
Phyxius Posted June 30, 2006 Share Posted June 30, 2006 yep, I have the same setup, and you have to have a tach converter. I forget which one it is... I'll try to look tomorrow and see which I have. Quote Link to comment Share on other sites More sharing options...
Thumper Posted June 30, 2006 Author Share Posted June 30, 2006 Ok I thought tach adapters were only for if you can get a signal but it reads way too high because of the multiple sparks at low rpms? I cannot get any movement on mine tachometer. But if a tach adapter converts the signal from one to another so that the tachometer can read it then that is what I need. Thanks Quote Link to comment Share on other sites More sharing options...
