Guest dr|ft Posted July 1, 2006 Share Posted July 1, 2006 Hello all! been reading Hybrid Z forums for years now.. never registered. Then finally had my swap done on my car. However, as the title states i do have problems w/ the drive shaft hitting the rear sway bar. Happens on downshifts and quick shifts. That is the worst combo right?!? no downshifting!! no launching!! Main question is i guess if im the only one. I guess i would have to get the drive shaft re done... or is there any other alternative? Im so close on just taking that swaybar off!!!! Let me know if other people have had that problem and what you all did to fix it. Thanks all. Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted July 1, 2006 Share Posted July 1, 2006 I didn't have a problem. My driveshaft does not hit my swaybar. My SR20DET is mounted as far back as possible. Maybe Alex at Vildini knows more. I used his mounts and with those mounts, I didn't have a problem. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 1, 2006 Share Posted July 1, 2006 do you have a 2+2? Quote Link to comment Share on other sites More sharing options...
Guest dr|ft Posted July 1, 2006 Share Posted July 1, 2006 Ah yes... i did not use Vildini's Mount.. our shop made our own. Not a cross member either. **newb aler** how would i be able to post pics of how the mounts look and how the motor sits? And yes.. i do own a 2+2... never thought about that... do you have an answer for me ON3GO!! Well i hope someone does. Thanks again for the replies Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 1, 2006 Share Posted July 1, 2006 i dont know the answer for ya. i just asked if it was a 2+2 as your driveline length is different then i think anybody else on here that has a SR20 Z... mike Quote Link to comment Share on other sites More sharing options...
Guest dr|ft Posted July 1, 2006 Share Posted July 1, 2006 That is true... *sigh* i wanted a 2 seater... hmmmm what to do... what to do. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted July 1, 2006 Share Posted July 1, 2006 make sure your differential mount isnt broken so that the diff isnt flopping up and down against the sway bar. Quote Link to comment Share on other sites More sharing options...
Guest dr|ft Posted July 1, 2006 Share Posted July 1, 2006 Now that... is an idea. Ill have to check that out. Thanks Quote Link to comment Share on other sites More sharing options...
Shift Posted July 2, 2006 Share Posted July 2, 2006 Yeah sounds like the diff is loose somehow. think about it, when launching, the diff case is more likely to move up in the front. down shifting has the opposite effect. Quick shifts, theres a moment that the diff is decelerating (pressing the clutch), which would also make the diff go down. Not trying to be a know-it-all, just bored and have nothing better to do. Most likely someone else is going to come along and prove me wrong anyways:mrgreen: . Quote Link to comment Share on other sites More sharing options...
Guest dr|ft Posted July 2, 2006 Share Posted July 2, 2006 Ill def have to check it out.. get it up on the lift and do some good investigation. Thanks for the input shift Quote Link to comment Share on other sites More sharing options...
