roadster?
lazycyril
working on my new 69 roadster1600 project.
been having trouble with the stock su type carbs. Thinking of fabricating in
some sort of fuel injection system.
Any reccamendationa for 1.6 liter nissan engine with simple fuel injection
system I can port over? hoping to make my own airbox, attach a throttle
body to it and mount it to the stock intake. and in a couple
fule injectors on top and figure out a good place to mount an oxgyen sensor on the exhuast.
I could do a mega squirt but if I could just grab a complete setup from another car with the same size engine, was going to try that first.
Dont really care about power. Gasmilege would be nice.
Are the datsun 510 L16s compatible?
Failing that anyone got a complete KA24 motor/trans with all the goodies
for a retro fit?
For amusment I fitted the old webers from my z in. actually fit! hope the engine does not rock to much though.
The Nissan GA16 from the Sentras should be a decent donor for a 1.6 liter EFI system... but that car doesn't make even 100hp, I don't think.
I like your concept, though, swapping in an OEM EFI system.
The intake manifold in any case will need to be modified, I think. Unless you're going to run some sort of throttle body fuel injection (yuck)
Just using the stock intake maniifold, mounting throttle bodies to it, and tapping injectors into the runners might be an option.
A standalone would really be great for this setup, but you might get it to run on stock parts.
If you get anything stock, be sure to go pre-1996 to avoid OBDII, it will just complicate things further for you.
