goodoldjam Posted July 11, 2006 Share Posted July 11, 2006 It seems that my megasquirt is setup up for vr i need to switch it to hall for my 83. I just wondering if im doing everything and not sure about a few things. Im assuming d2 is jumpered for vr and should be cut. I noticed on the autotune site in the picture of there board that xg1 and xg2 looked to be jumpered do i need to do this also. Everthing on the board seems to be correct c12,c30 and r57 are all missing. Anyway blue is to removed and orange is to be added. Thanks in advance for any help guys. Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted July 12, 2006 Author Share Posted July 12, 2006 D2 is jumpered normally it is not jumpered for distributors with a large offset bias. So do i leave it? For the Hall sensor, optical sensor, coil negative terminal or points: Jumper XG1 to XG2 on the bottom side of the PCB, near the 40 pin socket, Jumper OPTOIN to TACHSELECT on the bottom side of the PCB, near the DB37 connector, opposite the heat sink. Jumper TSEL to OPTOOUT on the bottom side of the PCB, near the center. So i guess i do jumper xg1 to2. Quote Link to comment Share on other sites More sharing options...
