V8 info help
im lust wondering what all do i have to do to my Z to get it ready for a SBC.i just want 250 to 300hp nothin special.what will need upgreading as far as sups.,breaks,driveline,rearend,and anything else you guys can think of
thanks for your help
Joe-Z
Z-ya L8ter
How about a 330 hp crate motor from GM for $2075?:
http://www.sallee-chevrolet.com/ChevySmallBlockV8s/330.html
Or the 350 HO Deluxe which is a complete motor, oilpan, to dist/carb with the Vortec heads for $3250? (same page) That puppy has over 300 lbft from 1700-5600 rpm!
You should upgrade stock suspension, brakes with this setup. While the R180 has been known to live under moderate powered V8s for quite a while, the R200 open diff is cheap and easy to swap in. Make sure you use good U-joints. Search the driveline forum for "solid u-joint" to find the one that Scottie found and used with success.
Other than that, follow the JTR (see the links page) manual and you're home free to lots of fun.
Cheers,
Pete Paraska - 73 540Z - Marathon Z Project
pparaska@home.com
Pete's V8 Datsun 240Z Pages
