proper piston rings needed.. urgent!
JaysZ
hi, on my F54 block i had some flat top pistons with 3 different groove heights. 1.6mm, 2mm, and 4mm. I mistakenly ordered the 2mm, 2mm and 4mm kit so now I need a new kit. RockAuto doesn't have the 1.6mm kit anymore. Anyone know where I can get these? I'm moving in a few weeks and this has to be done ASAP! Thanks!
Deves makes a good set of cast iron. Google "deves 280zx" and you'll find a few stores selling them.
PS. I know you won't want to hear this, but you could have found your answer yesterday by searching this site. "piston rings" would get you close, and "piston rings source" even closer.
I noticed you typed "ring" and I typed "rings". The search engine built into this site isn't quite as sophisticated as Google and so it thinks those are 2 diferent words and hence you get different results back for each. You have to anticipate the different ways the term will be used and search on them all.
Glad you found the Deves, I've heard nothing but good things about them.
