Guest alex86a2t Posted July 22, 2006 Share Posted July 22, 2006 Ok i am a little confused on how to hook up the crank angle sensor. So it has 4 wires, I suspect 2 of the wires give the signal every degree of rotation, and the other 2 wires give a signal every 60 degrees (each cylinder TDC). At least this what it looked like when i cracked the thing open. I am using a MS2 v3 board, with the relay board for easier and cleaner wiring. but i still can't find out where and how to hook up the CAS to the relay board. Thanks for the help, i am new to this board. Alex Quote Link to comment Share on other sites More sharing options...
mobythevan Posted July 24, 2006 Share Posted July 24, 2006 CAS connects to the relay board at the terminal input labeled "TACH" If it is an optical type unit(decoder wheel) you will need a pullup resistor like the L28ET instructions. Quote Link to comment Share on other sites More sharing options...
Shift Posted July 24, 2006 Share Posted July 24, 2006 Quote Ok i am a little confused on how to hook up the crank angle sensor. So it has 4 wires' date=' I suspect 2 of the wires give the signal every degree of rotation, and the other 2 wires give a signal every 60 degrees (each cylinder TDC). At least this what it looked like when i cracked the thing open. I am using a MS2 v3 board, with the relay board for easier and cleaner wiring. but i still can't find out where and how to hook up the CAS to the relay board. Thanks for the help, i am new to this board. Alex[/quote'] Your thought on how the sensor works is close but not quite. 2 wires are for power/ground and other 2 are the out put leads (one it 1* and I believe the other is 180*). With MSnS you only use one of the outputs. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted July 25, 2006 Share Posted July 25, 2006 The MSNS sticky thread has a diagram that uses a 280zxt CAS, but it has the same pinout. Quote Link to comment Share on other sites More sharing options...
