Magnum380Z Posted August 1, 2006 Share Posted August 1, 2006 How hard is it to change fuel injectors on 81 turboz I have never performed this before,so what do i need to do and what do i need to watch for? and its just one injector bad.....? any thoughts any body? Quote Link to comment Share on other sites More sharing options...
spotfitz Posted August 1, 2006 Share Posted August 1, 2006 http://autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/1c/46/0900823d801d1c46.jsp If you can swing it, replace the fuel rail with one of Pallnet's to make reinstalling everything easier: http://www.freewebs.com/pallnet/products.htm Quote Link to comment Share on other sites More sharing options...
olie05 Posted August 1, 2006 Share Posted August 1, 2006 the easiest way is to unscrew the little phillips head screws on the base of the injectors. Once all the injectors are off the manifold you can remove and replace one. Installation is the same as removal, just make sure all the o-rings are in the holes or you will have vacuum leaks. Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted August 1, 2006 Author Share Posted August 1, 2006 Thanks guys I apreciate it Quote Link to comment Share on other sites More sharing options...
