DRTY260Z Posted August 9, 2006 Share Posted August 9, 2006 I have a sbc 350 woith a few bolt-ons that include an edelbrock 750 carb, dual plane intake, 1.6 comp cam rockers, and long tube headers, everything else is stock.. The problem I'm having is that I get a rough idle and studdering on accelerration. I already tune the carb, & played with the timing. Can anybody help??? Please... Thanks.... Quote Link to comment Share on other sites More sharing options...
jt1 Posted August 9, 2006 Share Posted August 9, 2006 Two possible causes: Vacumn leak. Make sure all ports, openings, etc on the carb and manifold are plugged. Then use a can of starting fluid or carb cleaner to spray around the manifold with the motor running. If the idle picks up you have found the leak, correct it. Valves not properly adjusted, maybe holding some valves slightly open. John Quote Link to comment Share on other sites More sharing options...
DRTY260Z Posted August 9, 2006 Author Share Posted August 9, 2006 Thanks jt1 for answering back and yes I already tried checking for vacuum leaks, none found And as for the valves I also loosen them up and readjusted them with still the same problem Quote Link to comment Share on other sites More sharing options...
Guest mt 240-350 Posted August 10, 2006 Share Posted August 10, 2006 just a thought. i had a similar problem with my car. Rough idle(rougher than cam should allow) and running rich. I went to this web site and rewired very similar to what they recommended. Now I have full voltage to all the accesories. Made a world of difference for me http://www.madelectrical.com/electricaltech/onewire-threewire2.shtml Quote Link to comment Share on other sites More sharing options...
jt1 Posted August 10, 2006 Share Posted August 10, 2006 About the only other advice I can offer is to carefully check thru the ignition and timing. Pickup, coil, cap & rotor, wires, grounds. Make sure the engine is grounded to the frame somehow. Maybe then borrow a carb from somebody and see if that helps isolate the problem. John Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted August 14, 2006 Share Posted August 14, 2006 My immediate thoughts are the carb is to big for the application. The dual plane manifold helps with signal at low rpm's but even the primaries are hugh on a 750. If it's running and you've checked timing then it is most likely fuel related. Find another smaller carb to play with a 650 vac secondary would be more in tune with your setup IMHO. Quote Link to comment Share on other sites More sharing options...
