Removing RB oil pans/sumps???
S15 200sx owner
I used a thin bladed regular screwdriver, and using a rubber mallet I gently tapped the screwdriver in at one end, just enough to get through to the inside of the pan, then I tapped on the side of the screwdriver pushing the blade forward, cutting the sealant. When you get far enough along, you can use the screwdriver to gently pry it down the rest of the way.
good luck
Chris Rummel
I have used a blade from a power hack saw (about 1" wide 1/16"? or so thick) cut to about 8" long and sharpened like a chisel at one end, and grind the teeth off.
I have been using the same one for the last 20 years!!! I also be used as a gasket scraper (this was what I origionaly made it for).
I have used a blade from a power hack saw (about 1" wide 1/16"? or so thick) cut to about 8" long and sharpened like a chisel at one end' date=' and grind the teeth off.
I have been using the same one for the last 20 years!!! I also be used as a gasket scraper (this was what I origionaly made it for).[/quote']
That sounds like the business!!
Cheers all for your advice.
