hoov100 Posted August 23, 2006 Share Posted August 23, 2006 i was recently at a local auto parts auction and scored a aluminum (what the shop called it) BBC block, i figures since i have a 72 shell sitting there waiting for a motor i might as well drop in a motor i could build myself, so i bit the bullet on orderd a lunati "stroker" crank and some eagle h-beams since im gonna be spraying ALOT i might as well not have to worry about internals breaking, so here it begins...a BBC stroker buildup... Quote Link to comment Share on other sites More sharing options...
hoov100 Posted August 23, 2006 Author Share Posted August 23, 2006 ok, did the magnet test on the block this morning and its iron. also anyone have a set of heads they dont want?? Quote Link to comment Share on other sites More sharing options...
Guest EPS Posted August 24, 2006 Share Posted August 24, 2006 Do not just start bolting up parts! You will find poor performance and much expense. Educate yourself first. Talk, read and above all, take your time - atleast a year and then you can have sometning that performs and is not a HEADACHE! Quote Link to comment Share on other sites More sharing options...
hoov100 Posted August 24, 2006 Author Share Posted August 24, 2006 well, im about to start work at a shop the specializes in high performance chevy motors and whenever im not at home im either working on an sbc or an ls1, im just buying what i need when i can get it..i know what im doing as far as building it, its just the progress wont really start happening until i can save up enough for pistons, heads, rods, cam....etc im going with wiseco pistons and might be over-boring it .20 over. Quote Link to comment Share on other sites More sharing options...
