ihatejoefitz Posted August 23, 2006 Share Posted August 23, 2006 Another problem with my swap (81 zxt -> 240z). I plugged my fuel pump into the lead for switched 12 volt where the fuel pump relay is supposed to go because the relay was left behind when I pulled the engine. When I turned the key on, the fuel pump ran for a second and then stopped. Now, the green light on the ecu doesn't come on anymore. Is there a fuse or something inside the box that I can change? Quote Link to comment Share on other sites More sharing options...
