8/73 260z fuel relays
Guest harveje
Guest harveje
I want to do the alternator upgrade to a GM 12si, I know the elec. fuel pump runs thru 2 relays. Can someone walk me thru how I need to wire the new alt. and wnat to connect / jump at the voltage reg. box? Please?
I've read tons of post but most are for 240 or early 280 circuits. Also what is the 3 amp fuse just in front of the voltage reg. box, it has 2 white connectors. Like they said I think the 260 is the redheaded stepchild.....
yeah I have an 11/73 260. I only had fuses in the fusebox and then the two fusable links in teh engine bay. What you may have is something that was done in some shop.
There is a very thick white wire with a red stripe that is main power. You should be able to disect a little of the harness and figure out which one is going to the fusable link that goes back inside to the fuse box. I completely opened my harness up to seperate everything so that I would be able to make a new harness and eleminate everything unecessary (a lot!) I may convert to the 1 wire setup just to clean things up a bit.
hope this helps.
  • 1 month later...
Ive been looking for the same info as you on my 12/73 260z. I have a gm alternator and a bracket I made for an old 280zx I had. A friend of mine jumped some wires and had it all set in 10 minutes. Dont have the friend for my 260 conversion. Im searching for the swap info so I know what to do when my stock alt dies.
I didnt find much in a search but I did find one. This is what I found. "The heavy gauge white wire originally ran from the positive terminal on the starter to the shunt where it hooked up to a red/white wire. I cut the plug at the shunt, ran the white wire to the output terminal on the GM alternator and the other end to the starter. I ran the cut end of the red/white wire to the positive terminal at the starter. The positive lead from the battery also naturally connects to the positive terminal at the starter.
The starter terminal gets a little crowded, but I simply envision it as a bus bar that enables you to connect battery power to other critical circuitry in the car. The red/white wire formerly connected to the shunt provides power to the fuse block. It works and is pretty simple, though I have to admit that I was puckered up pretty tight when I first connected the battery."
Guest harveje
Well, I got the gm alt. on, disconnected the external regulator, got the fuel pump relays working, and the battery charging. I jumped the relay wires around but the elec. pump runs all the time when the car runs. Being lazy I used the fuel light on the dash as the alt. charging bulb. The RPM's have to get over 1k before it charges, I did not have to use a diode.
